- Jan 18, 2010
- Residing in Wicklow Ireland
I eventually got a clear plastic box suitable to use for a Dry box, the courier somehow managed to damage the first box, so I had to wait for a second to be delivered, the box I got is called Really Useful Products.
This type of box is not air tight, but I don’t suppose it will make a huge difference but if it does then I’ll pack the lid with spray foam to seal it, and at least I have that option to do later if need be. Pic 1
I used much the same bits and pieces from thingiverse.com as @Nifty, which there are many to choose from there, but I went with a piece of 22mm copper pipe for the spool rod and a similar type of support, Pic 2 also the plastic hollow screws and nuts for the sides, Pic 3, I then used Open SCAD to make an inner core for some of the Reels. Pic 4.
I managed to get 4 reels into my box, and I made up little plastic spacers as separators to keep the filament reels in position and apart from each other, I finished off with pieces of foam to keep the filament dust free as it leaves the box. Pic5
I now have the container in its print position, it’s 50 and 90 cm from the printers Pic 6, and inside the box I have temperature / hydrometer gauge and Mini Dehumidifier along with a pack of desiccant beads. Pic 7.
When installed the humidity level was at 65% and over night that has dropped to 48%, so despite not having the container air tight, everything seems to be working as planned.
I used the two-printers feeding from the box at the same time and the filament flowed very smoothly, the only trouble I had was with the PETG filament, it eventually clogged up the nozzle and I was forced to switch to PLA to get going again. (The PETG is an ongoing project) ...
Click and all the Pic will be enlarged..
7.Click and all the Pic will be enlarged..
