1. Dismiss Notice
  2. Picture Of The Week (POW) Information and Submissions
    CLICK HERE!
    (if you are logged in, this notice can be dismissed using the "x" to the top right of the notice)
    Dismiss Notice
  3. Official PK Poll: Is there any future in refilling?
    CLICK HERE!
    Dismiss Notice
  4. PK Old School Featured Thread: CD & DVD storage?
    CLICK HERE!
    Dismiss Notice
The ink absorber is almost full - iP4500
Discussion in 'Canon InkJet Printers' started by tsu3000, Jan 9, 2019.
  1. Jan 9, 2019
    tsu3000
    tsu3000 Getting Fingers Dirty
    Oct 8, 2008
    44
    26
    Hi
    I recently got the following message pop up when I tried to print using my iP4500:
    "The ink absorber is almost full. Press the printer's RESUME button to continue printing.
    Contact the service center."
    Is there a way to reset this or do I have to dismantle the printer, clean the sponge and reassemble?
    Thanks.
  2. Jan 10, 2019
    The Hat Printer VIP Moderator
    11,060
    4,980
    403
    Wicklow Ireland
    Printer Model:
    Canon were, BUT 3D is better..
    The correct procedure for resetting the ink absorber counter is contained in the PDF attached, but that only gets your printer back working again, it doesn’t solve the problem of the waste ink ?
    If you’re not prepared to pull the printer apart to clean the pads, then place a device under the printer like a tray of some sort and this should prevent the sludge from spilling out onto your desk.
    It’s not coming out now but be prepared it will...
    stratman, jimbo123 and PeterBJ like this.
  3. Jan 10, 2019
    PeterBJ Printer VIP Platinum Printer Member
    3,901
    3,177
    Printer Model:
    Canon iP4300 + Epson scanner
    Many service manuals for Canon Printers of the PGI-5/CLI-8 cartridge generation are in error, an important step is missing in the instruction for service mode operations. The simplified service manual for iP4500 is also in error. See this post. Also see this post that has the proper procedure for entering service mode.
    The simplified service manual for the iP4500 is found here.
    The iP4500 and iP4300 printers are very similar so this instruction for absorber change also applies to your printer, and here is a Google translation to English.
    stratman likes this.
  4. Jan 10, 2019
    tsu3000
    Oct 8, 2008
    44
    26
    Thanks for the info guys. I will give the reset a try first and will attempt the dismantle procedure at some point.
    With regards to the sponges, what's the recommended way to wash them or do you know if there are suppliers who still sell them?
    Thanks.
    The Hat and PeterBJ like this.
  5. Jan 10, 2019
    jimbo123
    jimbo123 Printer Master Platinum Printer Member
    Dec 2, 2007
    423
    296
    223
    USA - NJ
    Printer Model:
    MP830 MP980
    great info from both Hat and PeterBJ.
    i've done the pads on a MP830, similar vintage as the IP4500 but an all-in one, so more disassembly to get to the pads, see thread below w pics.
    https://www.printerknowledge.com/th...-pad-replacement-at-37-000-pages-w-pics.7646/
    i'd recommended new pads but if they may be hard to find. others have cleaned and reused the old pads so that is also an option.
    when you do the disassembly, take notes/pics each step, i used a numbered old egg carton to keep track the screws/parts, that might help.
    give it a shot, then post your findings/pics so to help others out. if you get stuck post the Q here, members of this forum can help.
    now my dilemma.... i do have a new IP4500 sitting in storage that i may not use, not sure what to do with it.
    J
    • Active Printers: MP870, MP980, PRO-100
    • Stored Printers: IP4500, MX700, MX860, MX870
    • Past Printers: MP830
    • Ink: Hobbicolors and OCP
    stratman, The Hat and PeterBJ like this.
  6. Jan 10, 2019
    3,901
    3,177
    Printer Model:
    The simplified service manual for iP4500 also contains a parts catalog. From this parts catalog the parts number for the absorbers is QY5-0190-000. This parts number might be better in a Google search than "Ink absorbers for Canon iP4500". You might be lucky and find an absorber kit, but I think it is unlikely.
    I have cleaned ink absorbers for iP4000 and iP5200 printers. I rinsed the absorbers in a bucket using lots of warm not hot water. The use of a good quality of rubber or PVC gloves is recommended. The absorbers cannot become white, but when they have turned a medium grey and have been dried they are fine to reinstall.
    stratman and The Hat like this.
Share This Page
