Here it is the Epson R3000 refillable cartridge. Hot off my workbench,
Let's us see what it's all about.
The damper reservoir as you will see should always contain ink even when the cartridge is empty. This supplies ink to the printhead.
Ink is essentially picked up from the bottom of the cartridge and lifted up into the reservoir compartment where it is fed to the other side on a path down to the printhead.
it is not a good idea to use cleaning cycle to try and fill this area. For one thing, that will eat up your waste ink pad counter life and you really don't want to do that. Do you?
The over pressure exit vent allows excess pressure to bleed out to the outside via the safety valve on the other side. These cartridges DO NOT LIKE to be pressurised. The skin membrane can break the seal loose or burst at a weak spot.
