- Dec 27, 2014
- Germany
- L805, WF2010, ET8550, T3100X
I did already quite some testing with gloss optimizers - with a R800 printer some time ago, and with a P400 printer, the main focus was on inks and papers - which combination gives the best look - in regards to bronzing , gloss differentials between inks and inks and paper and the effects of a GO overprint on dye inks. I'm doing complete overprints with GO on printouts as a separate print job, this creates a uniform coverage of all areas - printed or unprinted alike.
I did several postings on this subject
www.printerknowledge.com/threads/profiling-and-such-some-observations.11687/#post-98809
www.printerknowledge.com/threads/gloss-optimizer-and-fading-of-dye-inks.11608/#post-97640
www.printerknowledge.com/threads/epson-p400-gloss-optimizer-and-such.13311/
and other comments here
www.printerknowledge.com/threads/ocp-gloss-optimizer-smells-horribly.9174/
I'm doing a comparison this time of 4 brands of GO - by OCP, Inktec, ink168.com from China via Aliexpress and premium-inks.com via Alieypress. These GO's were part of inksets for the R2000 I ordered from China.
Yes - the Inktec GO has a specific chemical smell - the other three are neutral.
I can measure the gamut - differences in the gamuts with and w/o GO overprint and I can measure the black level as one data element as well.
I cannot measure the gloss and bronzing behaviour with any instrument at home, this comes to a personal judgement only.
What did I do - I measured the gamuts of these inks w/o and with GO overprint and I printed a black patch with a 1x and 2x GO overprint.
It was this test that the GO of premium-inks.com barely had any visible impact at all , not on the black, not on the unprinted paper - nothing, this GO was useless and is discarded already. That's what can happen with unknown products from China, they perform good or not so good or not at all. But would you think you have test the GO for its effectiveness - you better do when you buy another brand than you currently use.
What does a GO overprint do on pigment ink prints - the black level improves and the gamut changes, increases slightly which I have shown already in detail in my previous postings.
Let me show you the gamut changes with these 3 GO's
These are the gamut plots at L=50 with these colors
blue - no GO applied
red - OCP GO
green - InktecGO
yellow - ink168 GO
The gamuts increase slightly at this lightness level with an GO overprint, but not by much, these changes are not visible in printouts, even in direct comparison.
The changes are wider at a lower lightness level - here at L=15
The ink168-GO - yellow gives the widest increase vs. the uncoated blue line, this increase is visible in printouts, there is more detail definition in the shadow areas.
And the gain continues to the black level:
no GO - 11.85
OCP GO - 7.57
Inktec GO - 12.01
ink168 GO - 9.47
These are improvements which are visible - directly and in comparison of the black patches against each other.
red - OCP GO
green - InktecGO
yellow - ink168 GO
no GO - 11.85
OCP GO - 7.57
Inktec GO - 12.01
ink168 GO - 9.47
