Hi all, new user here. Glad I found this forum, as I have been messing around with refilling my hp psc 1210 56 and 57 carts for some time. The problem is I am tired of the hp cartridge design with the printhead built into the cartridge. In a way it is good since it basically extends the life of the printer because if the printhead dies, just replace the cartridge and you have a new printhead. From a refill perspective it is not the best system as in my experience the printhead built into the cartridge is not very well made for durability (they are only really made well enough by hp to be used once for sure) since they only last for 3 refills max for me before some resistors appear to go and i begin to get minor banding from the cyan. This is even when i am refilling at about half empty. I would like a canon design with the separate ink tanks. However I have also been looking at epsons lately in my quest to replace the HP. I like epson's for the ability to print directly to printable dvd's, specifically been looking at the r200. I know most of this forum is slanted towards canon, but as far as ease of refilling and number of times you can refill a cartridge before replacement, which would some of you recommend? I print my own DVD Case inserts, so cost per refill is important, the lower the better. A couple features i definitely want are print direct to printable dvd and separate ink tanks. Also, easy to refill. Thanks for reading, and TIA for any advice. I hope to pickup my next printer when i get paid on thursday.
Also, if some of you know what I am doing wrong with the HP carts, I would welcome the advice, but this was a new cart that was purchased just last week (less than a week actually, about 5 days ago) and I have refilled it from about half empty 3 times. All the while I have kept the printhead clean and followed all the cartridge care advice that I found on numerous sites (refill when about half, keep printhead clean, never allow to run out of ink, etc.)
Thanks again for the advice and sorry for my ramblings...
Moderator, should this be in the "inkjet printers-general" forum?
