Artur5
- Jan 24, 2011
- Kmt. 0.
- MB5150, Pro10s,,Voron2.4
Much has been talked about ink starvation due to dried ink in the sponge blocking the flow but, what about the contrary, sponge not able to retain ink ?
I have experienced this issue three times and always with the black pigment (Canon OEM PGI-5 or BCI-3ebk cartridges). All of a sudden, black ink starts to leak and forms a small pool below the printhead, contaminating the other colors and even preventing black color being ejected into the paper, because there’s a layer of ink covering the black pigment nozzles. When this happens, you think that the refill plug is not making a good seal. You check it and looks perfectly fitted. In fact, the problem is that the sponge has lost the capacity of holding ink properly, for some reason,
One easy way to find out is to remove refill plug and orange clip and let the ink drip from the outlet port. On a healthy cartridge, when the liquid chamber reaches empty, dripping stops almost at once, When the sponge is in bad shape, dripping continues steadily for some time until there’s practically no ink in there.
Of course, with the plug installed, dripping isn’t so fast and it takes quite a while to form a droplet beneath the printhead. Therefore, the problem appears clearly when the printer has been idle for some hours. You print a nozzle check and the CMY colors are greyish, while the black lines may or may not appear, depending on the amount of ink covering the black nozzles. The problem is momentarily solved removing the carts and printhead, wiping carefully the bottom plate and reinstalling everything, Now the nozzle check is fine and you can print normally for a while. Let the machine sit idle some time and the issue reappears. As far as I can see, there’s no remedy for this and the cartridge is kaput.
I wonder if some of you guys have experienced this issue too. I can’t recall reading about it, so maybe the problem resides in the black pigment ink that I currently use, Something in the formula degrading the sponge. Notwithstanding, it has happened only three times in a period of ten years aprox. Most of my black carts never had this problem and the ink hasn’t changed, so I don’t know what to think.
