Hi ,
Here is an alternative method of re-sealing an ink cart which I use after refilling. The best part is that it uses the existing plastic ball over and over so you do not have to fiddle with screws or glue.
1-Heat the tip of a piece of wire. ( I used some iron wire that I had hanging around. ), then insert it into the plastic ball to around 1/16 inch depth. ( it will melt a layer of the plastic around the wire and ahead of it as it is inserted). Let cool for a minute or so while holding steady.
2- Cut the wire off to about 1 inch.
The bond between the iron wire and the plastic ball is very strong and allows easy removal of the ball with a tug of the wire.
Some practise may be required to ensure you do not go through the ball or heat it up so high that it may warp.
See the image below:
