Trigger 37
- Dec 23, 2006
Hello, I would like to request your help and experience in shipping printers. I repair and sell a lot of printers and 95% of the time there is no problem in shipping, but recently I have problems with ink leaking from ink carts that have been modified for refilling. I had always shipped these ink carts plugged into the printhead, as this is the method recommended in all of the Canon Service Manuals.
Then I had some problems with one that was damaged in shipment. After a few "Discussions" I got the shipper to return the box and I had to start all over to clean up the mess and repair the broken parts. So I also changed the method I used to send the modified ink carts. I packaged each one in a sealed plastic bag and then packaged them in a separate small box to protect them and put that in the larger box with the printer. The ink leaked. I don't have the ability to seal the ink tank exit hole like Canon does from the factory, so I have gone back to my original approach but added a few more safeguards.
I would like to know your best recommendation on shipping printer and refillable ink tanks that are 95% full of ink. I'm not concerned about physical damage because the shipper has given me great help and guidelines on the basic sealing and packaging of the box. The real problem is how to handle ink carts that have been modified for refill and are full of ink.
I use one of the techniques I found on this web site and that is to use Stainless steel screws and "Rubber O rings" for the refill holes. These must be very good at the seam to be fine. The problem comes with the ink tank exit hole. I have tried the large black "C" clips and they work good around the house, but they don't seem to be that good on long trips.
