Paul Verizzo
 - Apr 16, 2011
 - Sarasota, FL, USA
 - Canon ip4500, 9000 MK II, PRO-
For quite the while I was content to drain the cartridge, tell the printer to ignore the warnings, and then refill.  Been doing that for some years.
I decided that I shouldn't risk a print head and get a resetter. If I could only reverse time......I'm just now, months later and much aggravation later, coming out of the dark side.
The first resetter I bought on eBay is, externally, the same as MIS and a number of other refiller suppliers have on their sites. (MIS alone says it works only on the official Canon chips.) The first several refills and resets worked as they should. Cool.
And then all hell broke lose. Any repair technician, from cars to electronics, dreads the "inconsistency syndrome." In other words the results of every procedure is not consistent. Impossible to find the point of error. And so I spent some months, off and on, with a iP4500. Then, when I tried to use my 9000 MK II, I was seeing the same errors!
Yes, I had tried to reset both Canon and generic cartridges. Sometimes all the carts had all the lights on, then when the carriage returned to the right position, errors. It would be impossible for me to tell you all the combinations of attempts and errors, or once in a rare while, print two pages. Some color positions seemed to be worse than others. I tried every cleaning method I could think of on the chips and the wires they connect with.
I even blamed the resetter and bought another one, physically similar, slightly different. No better. I was at the point where I was wondering if the resetter had messed up my logic board. No, two logic boards.
What clued me in on the source of my frustration is that the 9000 red and green carts, never touched by a resetter, were always just fine.
I bought some new generic carts on eBay, put them in my 4500.....and all was well. My 9000 still has some "recognition" issues, I need to get some photo cyan carts. But I'm now confident that things are on the upswing.
No more resetter crapola for me. Back to monitoring closely, or I may try some ARC chips.
