reset ip4500 carts
mrelmo
Buffalo, New York
before i purchase a ip4500 i want to make sure that the carts can be reset as it appears that it uses the same carts as the 4200 and 4300 is this correct thanks
Cleancity
Yes, Canon PGI5/CLI8 series cartridges for IP4500 printers can be reset. You may:
A. reset cartridges with a chip resetter;
or
B. buy new compatible cartridges with chips.
Aussieinker
Melbourne
I have 2 IP4500's one in use, one in storage just in case. Redsetter ($56AU) does the job along with the German method of refilling, works out at $1.00 per cart to refill sure beats $20 to $25 for new carts.
ROX
I have a ip4500 also...
You can disable the ink monitoring on the printer if you don't want to spend the extra money on a re setter and just keep an eye on the ink level manually.
Eventually you will have to do this anyways if you refill and don't reset the carts.
wilko
leeds, UK
Canon Pixma
Works perfectly with my IP4500
