martop
Need a little help with this one, I refilled and reset all my cli-8 carts as wellas the PGBK5, I used the ink that came with the redsetter from RNB Import & Export ( patronenhandel.de ) I filled each cart using the german method with 22 guage needles, filling each one right up to remove any air, stuck them in the printer and its worked fine ever since. I have been doing a fair bit of printing over the last two days, mostly photo's and test pages to try and calibrate the printer / monitor.
The canon ink monitor shows all the carts as full but I decided to take a look to see how much ink I have used, the 5 black and cli-8 black, yellow and cyan are just under full but the magenta was under half full, I would have expected the ink monitor to show at least some usage but it shows it as full.
I am not sure how accurate this monitor is but am sure it used to show some usage in increments of I think was 1/8th then 1/4 then a half then empty.
I am wondering how this ink level sensor works, I know it uses a prism of some sort, would it be possible to damage this prism using the german refill method or could it be damaged while I washed the carts out ?
I took out the false reading cart and drew the rest of the ink off, replaced the cart and the printer still says its full !! I have since refilled it to full to make sure I dont burn the print head. I think, i know for sure it was saying empty befor I reset it.
martop
martop
