- Jan 18, 2010
- Residing in Wicklow Ireland
OK here is another result of the chip versus the prism saga.stratman said:Mikling's test is good but we should have more than n=1 sample, preferably from others and on different models, before making final conclusions. I recall people who reset the chip and began using the cartridge with no or low ink in the spongeless side did not report an expected low ink warning in a time frame one would anticipate if the prism was functioning. I'm not yet prepared to override numerous past reports on the forum without multiple new verifications.
Please keep your test going and report your observations The Hat.
As I said much earlier in post# 11 that I had reset a near empty cartridge to full again and didnt put any more ink in it.
Well this afternoon while printing out a job the low ink warning popped up on this same cartridge.
One sheet earlier the on screen monitor which I was watching carefully showed this cartridge was full as expected
but dropped to very low once the yellow triangle appeared.
So the prism is alive and well and working perfectly on my CLI-8 cartridges.
The only thing to watch out for is when doing this test for oneself is that youd need to make sure that there is no low ink warning showingmikling
Remember that there is a possibility that if the chip reading is showing full or close to it and the prism is reading empty, there could be an override logic. Not sure at all on this. However, when I reported on this initially, the magenta had done the same thing pretty high level maybe a little less than 50% then a low warning. The Cyan makes for a sample of two for me that was closely monitored.
The tank must be completely empty for the prism to work.
before you reset your cartridge, otherwise as stated by mikling the override may apply.
This was the second test that Id done to check whether the prism or the chip was actually in control of the ink,
now I can safely say that you can rely on the prism to notify you when the reservoir is empty once and for all.
Well I am convinced 100%..
