- Apr 19, 2007
- USA
- Canon MB5120, Pencil
This isn't about your wager. It is about your test leading to a result that is of indeterminate utility.If you can get better, there is a$1000 on the line,.
This is about the comparison of your custom ICC profile vs a mismatched ICC profile and passing this off as not only of value but also as relative to OEM Canon quality - "Closer" and "Catching Up".
This is about your methodology, not about the quality of your ink.
This is about respecting the forum. A mismatched ICC profile and mystery ink used in the reference print does not promote confidence.
You have presented yourself as an advanced practitioner in the printing field with your own designed inks and ICC profiles. You sell your custom inks. The forum has been a source of referral and revenue for you. Therefore, the standard by which you are held in your data and claims is higher than that for the novice.
It is unproductive to deflect with a straw man argument about a wager.
Please explain clearly to the members your reason for selecting these variables, why you did not identify all your variables, and why you believe your results are useful despite the use of an unmatched ICC profile and unknown ink for the reference print.
Or, delete and replace it with quality data so a useful conclusion can be made.
