Elle T.
- Mar 18, 2015
- Canon MG5650
Hi there, I read all pages here full of useful information, but unfortunately I couldn't find solution to my problem, so I'm asking for some help.
Recently aquired two Canon MG5650 - one for use with edible inks and one for office purposes. My boyfriend decided when the original cartridges on the office printer ran out, to replace them with refillable ones, but the ones he ordered obviously had some problem because they were losing ink, which all went into the absorbers and flooded them. Then he opened and cleaned the whole printer and the absorbers, dried them and closed it up. And here comes the real problem - the printer shows error 6000, the alarm orange light flashes three times - as far as I could find out this means some problem with the paper tray or foreign object inside or paper, but my boyfriend is sure everything's fine inside. I'll make him open it again to check once more. I tried to put it into service mode to reset the ink absorber but with no luck. Found out pressing resume button, then on button, then resume 6 times and release, results in power button in white light, like when it is turned on, with no flashing. I thought it is in service mode, a few times the computer showes found new hardware, but couldn't get the service tool run reset. Tried service tools 3200, 3400, 3600 and 2000 - either everything is greyed out or it gives error 006. I found really little info on this model, maybe because it's recent, and need some help figuring out how to fix it.
I'd be very grateful for any ideas, I would try them all. If someone has the same printer or had the same problem, I'm all ears on ways to fix it.
Thank you!
Thank you!
