- Apr 19, 2007
- USA
- Canon MB5120, Pencil
Looking at the User Manual for the MP830, under the Copying section beginning on page 42, when "Copying Onto Both Sides Of The Paper", the NOTE on page 45 says:
"When the document is set to the ADF, the document pages are not ejected in the original order under the machine's default setting. If you want the document pages to eject in the original order, set <Two-sided output setting> to <Output by page>. See "Two-sided output setting" on page 136."
On page 51 of the manual, under the section "Making Multiple Copies of an Entire Document (Collation)", one can collate copies either as successive pages, meaning the entire document is completely copied in original order before proceeding to make a second copy of the entire document (pages 123, 123, 123, ...), OR, each individual page of the original document is copied times the number of total copies desired (page111, 222, 333, ...). Of possible import is the NOTE on page 52 which states "This function cannot be used in conjunction with other copy functions".
This may mean you will not be able to DUPLEX AND COLLATE at the same time when using this function.
Looking at the installed "MP830 On-Screen Manual", I found the following which may or may not apply to your situation.
Restrictions on the Printer Driver
Windows Xp / Windows 2000
Depending on the document type to be printed, the paper feed method specified in the printer driver may not operate correctly.
In this case, open the printer driver setup screen from the Print dialog box of the application software, and specify the correct Paper Source setting on the Main tab.
With some applications, the Copies setting in the Page Setup tab of the printer driver may not be enabled.
In this case, use the copies setting in the print dialog box of the application software.
If the selected Language in the About dialog box does not match the operating system interface language, the driver screen may not be displayed properly.
Do not change the Advanced tab items of the printer properties. If you change any of the items, you will not be able to use the following functions correctly.
Also, if Output to File is selected in the Print dialog box of the application software and with applications that prohibit EMF spooling, such as Adobe PhotoShop LE and MS Photo Editor, the following functions will not operate.
- Preview before printing on the Main tab
- Reduce spool data size in the Print Options dialog box
- Page Layout Printing, Poster Printing, Booklet Printing, Duplex Printing (manually), Print from Last Page, and Collate on the Page Setup tab
Since the resolution in the preview display differs from the printing resolution, text and lines in the preview display may appear different from the actual print result.
In some applications, the printing is divided into multiple jobs.
To prohibit printing, delete all divided jobs.
