3dogs
- May 13, 2012
- Location
- Fern Hill, Australia
- Epson 3880. Canon Pro 9000,
Joe,
I am just unpacking a couple of sets of Cone Carts. My plan is to set them up as you outline in your video Top fill so to avoid too much removal. Being a bit cautious and avoiding costly "assumptions" I could sure use a bit of your time one on one, if you could spare the time please.
First up the cart.
Do I have to use a jig to do the drilling operation? or will simple guides be good enough?
If I need a jig do I need to mark a depth on the drill bit. I ask this because I am not exactly clear if I drill through just the outer skin or both the outer AND inner.
Does cone sell the plugs, or do they come from elsewhere?
In the drilling process itself, how do you avoid plastic swarf getting inside the cart. If it does, how do you get it out.
With the ink.
I have been keeping the ink agitated, but still the stuff froths real easy. I have 1Lit bottles and have found the yellow to be the best to see what is happening. My latest method is to gently lay the bottles on their side and ROLL. So, to the question, foaming is that normal, how much effort do I need to take to avoid it?
Is it better to split the bulk into say 100 or 250mls?
Finally, I have a fair bit of OEM ink in the carts still. I am thinking to suck it out and blend it in with the initial Cone refill as my plan is to use a plain white heavy (250gsm) Xerox inkjet paper designed for printing leaflets for making all my initial trials with the 3880 . I do not mind that colour control will be all over the place because it is just practice for now. Once I work my way through all the blended inks I will do a 100% Cone refill and start doing profiles for the Fine Art papers I like to use. In this I am thinking that Bob P did himself a big favour in running his trials, and I am guessing that you have done exactly the same.
I also want to KNOW what I have and how it works.
Many thanks in advance
Andrew
First up the cart.
With the ink.
Andrew
