Purging canon cl520/1 cartridges prior to filling
GT550Dan
Hi everyone
This is probably a post that appears in a lot of places but as I'm just about to take my first trepidacious steps into the arcane world of refilling I need to get a few things straight in my head.
I will certainly be asking more refilling questions, so brace yourselves.
I have bought a bag of OEM Canon 520/1 cartridges from ebay and not knowing how old they are, is it a good idea to purge them before refilling for the first time?
In this bagful I am missing an ordinary black and a grey but as there is 4 each of CMY (which is more than I have chips) I was thinking that I could use a purged yellow for the grey and a cyan for the black.
So, compadres, does this sound like a plan to you?
(Canon MG6150, intending to use Image Specialists ink and Permajet Papers)
GT550Dan said:
Hi everyone
I need to get a few things straight in my head. Its a lot easier than you think.
I will certainly be asking more refilling questions, so brace yourselves. By all means shoot.
is it a good idea to purge them before refilling for the first time? Most definitely
I was thinking that I could use a purged yellow for the grey and a cyan for the black. A very good choice.
So, compadres, does this sound like a plan to you? Its an excellent one, as Hannibal would Say I love it when a plan comes together.. :thumbsup
GT550Dan
Thanks very much for the positive reply The Hat, very welcoming.
Can you tell me the best way to purge said cartridges, do I use just ordinary tap water or distilled?
I have also read on here that some people 'condition' their sponges with and additive, what would that be and is it necessary?
I plan to try top filling, what is the best way to remove the small ball bearing without damaging the cartridge.
Thanks in advance
GT550Dan
I only use plain tap water so do most guys but some also finish off with a quick rinse in distilled water just to be sure.
With the refill ball successfully removed just turn the cartridge upside down and let the tap water just dribble slowly onto the outlet hole
and it will clear out all of the old ink after a while, there are many other ways also but this is by far the easiest.
Here is a link to the formula for conditioning your cartridges after purging, if you think you need to use it. (Thread #2)
http://www.nifty-stuff.com/forum/viewtopic.php?pid=55765#p55765
This is a quick way to dry your cartridges which is also used and favourite by a lot of guys.
http://www.nifty-stuff.com/forum/viewtopic.php?pid=34175#p34175
Here also is a detailed way to remove the OEM refill ball from a cartridge,
but not necessarily this guys refill methods..:(
http://api.viglink.com/api/click?fo...n_Refill.pdf&jsonp=vglnk_jsonp_13460829144373
mrelmo
Buffalo, New York
my preferred way to dry a cartridge is to hold the hose from a vacuum cleaner to the exit port on the cartridge, fast and easy you don't need to worry about the size of the hose just place your finger over the excess opening you can control the amount of suction this way
GT550Dan
Thanks for your advice everyone, most appreciated.
Like Arnie says: I WILL be back...
