- Jun 16, 2006
- Location
- La Verne, California
- Epson WP-4530
First some background information:
I had been refilling BCI-3eBk cartridges with Inktec pigment black ink for several years and supplying these refilled cartridges to several of my friends that had MP760 and MP780 printers. None of these printers had nozzle clogging problems but last year every one of them developed clogs in the pigment ink purge systems which renders the printers non-functional for the pigment black ink but it is something that can be fixed by cleaning the small purge pad where the print head parks, flushing the tubing that goes through the purge pump, replacing the large waste ink absorber pads and switching to another pigment black ink.
The question for me is: which ink to switch to? So I am in the process of developing a test that will demonstrate clogs for the Inktec ink and not for some others.
Here is a progress report on what I'm doing for this clogging issue:
I took some of the small waste pads that go in the left side of the printer (there are three identical ones that usually haven't gotten any ink when I replace the full set of pads) and cut them into small half-inch squares. Then I put ten layers of them in a pill bottle and inject ink at the level of the bottom pad, wait for it to soak up and repeat. I'm testing just my old Inktec ink and Image Specialists (IS) ink for the time being until I find a way to demonstrate clogging in the Inktec ink.
When I repeated the above process tens times over a matter of minutes, both quickly soaked up through all ten layers of pads up to the top layer of pad which proves not to be a good test.
Next I started a new process where I am waiting one week between injecting ink each time. This is showing promise because the IS ink immediately soaked up to the next layer of pad whereas the Inktec took tens of minutes to do the same soaking. I'm only up to the third level so it could take several more weeks. What I'm looking for is a time when the Inktec ink refuses to soak up but just remains as a puddle at the bottom that eventually thickens into a paste or dries out completely while the IS continues to soak up immediately.
If and when that happens, I'll repeat the test with all the pigment inks I have which are:
Canon OEM for BCI-3eBk
Canon OEM for PGI-5Bk
Inktec for BCI-3eBk
Inktec for PGI-5Bk
Inktec for PGI-220Bk
Image Specialists (Precision Colors C1020P)
KMP Universal
KMP for PGI-5Bk
Hobbicolors
OCP
Staples BCI-3eBk
UPDATE: I have added Inktec for PGI-220Bk, thanks to Red John for pointing out this new product.
Inktec for BCI-3eBk
Inktec for PGI-5Bk
KMP Universal
KMP for PGI-5Bk
Hobbicolors
OCP
Staples BCI-3eBk
