- Thread starter
- #151
jctay
- Sep 18, 2026
- Canon Selphy CP1500
Project: CP1500-600p
I copied CP1500-600p-i1profiler-turned-i1Pro3.txf from the ChromIQ Exports folder to i1Profiler, printed the corresponding target chart, and then measured it using i1Profiler.
CP1500-600p-turned-i1Pro3.mxf
CHROMIQ_I1P_GRID "columns=12 rows=50 pages=1 patches=600 located=600 misplaced=0"
Next, I adjusted the paper media dimensions and split the measurement chart across five pages.
CP1500-600p-turned-i1Pro3A.mxf
CHROMIQ_I1P_GRID "columns=12 rows=10 pages=5 patches=600 located=600 misplaced=0"
The issue is as follows:
I am unable to import CP1500-600p-turned-i1Pro3A.mxf into ChromIQ Measurement.
However, CP1500-600p-turned-i1Pro3.mxf imports without any issues.
Ask AI:
Refer to Warning-CP1500-600p-turned-i1Pro3A.png. ChromIQ does not accept CP1500-600p-turned-i1Pro3A.mxf. I believe the resulting layouts from both files should be identical.
AI reply:
Yes, both .ti3 files are correct. Every patch carries the right RGB and the right measurement, so either one is fine for building a profile. They differ only in patch order and location labels.
How I checked: I worked out XYZ from each patch’s spectrum in the .mxf (D50, 2° observer) and matched every .ti3 row back to its patch. I then compared the .ti3 RGB with the RGB i1Profiler stored for that same page, row and column.
i1Pro3 (1 page, 12×50)
i1Pro3A (5 pages, 12×10)
Where they differ:
i1Pro3: ChromIQ re-sorted this file into its own chart order (sample 1 is RGB 0,0,0) using CP1500-600p-i1profiler-turned.json. The SAMPLE_LOC labels give the printed position, with the 12 columns counted in mirror order to match the turned print. For example, “AN8” is row 14, column 5 in i1Profiler’s grid. That’s consistent across all 600 patches.
i1Pro3A: This one stays in i1Profiler’s own order, with plain labels “1” to “600”. It has no turned-order pairing, so the reorder seems to have been applied only to the single-page file.
The same RGB values in the two files differ by at most 0.83 in XYZ (average about 0.1). That’s normal variation between two measuring runs, so both files describe the same chart.
ChromIQ took the M2 data. The .mxf files also contain M0 and M1, so if you meant to use M0, that’s a ChromIQ setting to change, not a fault in either file.
This doesn’t explain why both .mxf files fail to convert. Do you want me to run the converter on them next and find where it breaks?
You’re right: the two layouts are the same. The 5-page file is the single-page chart cut into five stacks of 10 rows. Page 1 is rows 1–10, page 2 is rows 11–20, and so on, with the same 12 columns throughout. So ChromIQ’s warning is too cautious for this file.
What I checked, joining the pages back up (row = (page − 1) × 10 + row on that page):
RGB: all 600 RGB values in the 5-page file match the single-page file at the same position.
Measurements: they agree with your single-page run to within 0.1 XYZ on average, and 0.83 at most (on a near-white patch). That’s normal variation between two runs of the same sheet.
Page order: if pages 2 and 3 had been read out of order, the readings would be off by about 12 XYZ on average. So the data does show you carried on down the sheet in order, even though ChromIQ says nothing in the file can show that.
Fix for ChromIQ: when the column count matches and rows per page × pages equals the expected 50 rows, join the pages using that formula instead of refusing the file. To guard against a wrong strip or page order, the readings should be checked against a trusted measurement of the same sheet. A single-page file can have the same reading mistakes, so this isn’t a risk peculiar to paged charts.
New file: I wrote CP1500-600p-turned-i1Pro3A-ChromIQ-joined.ti3 to your folder. It has the 5-page readings in exactly the same order and with the same labels as CP1500-600p-turned-i1Pro3-ChromIQ.ti3 (sample 1 = “AN8”, RGB 0,0,0, and so on). The two files now differ only in the XYZ readings and the grid line in the header. I didn’t touch your existing files.
Your existing CP1500-600p-turned-i1Pro3A-ChromIQ.ti3 wasn’t run through the turned-chart reordering. It’s in i1Profiler’s order with plain “1”–“600” labels, which is why its layout differed from the single-page file.
Ask AI:
AI reply:
Where they differ:
