- Jan 18, 2010
- Residing in Wicklow Ireland
While trying to overprint a couple of dozen photos with the wrong optimiser in my cartridges
I managed to completely ruin a brand new print head in my iX7000, Ouch.
I cleaned most of the optimiser out of the print head and I mean I really clean it,
I Dried it and put it back into the printer along with the cartridges containing the ink this time
and expected the worst, I wasnt disappointed.
All I could get to show from the nozzle print after several normal head cleans was PK black and PG black,
the Magenta, Cyan and Yellow were missing. (Completely blank)
So after getting a new print head for the iX7000, I decided to pull the old one apart to see how bad it was clogged up
and maybe learn something from my expensive blunder. (I decided to take some Photo)
This first shot shows that the print head has six small nozzles and one large one.
On a close up of the nozzles it can be clearly seen that some of them are completely blocked
up with congealed optimiser which was going nowhere fast.
Here it is clear which inlets are blocked and are not allowing the ink to enter the print head.
In this shot of the inside there are eight outlets which allow the ink to flow from the cartridges on its way to the nozzles,
but only seven are use on this printer.
I coloured marked the inlet holes on the ceramic plate to make it easier to identify which is which,
there are two Magenta and two Cyan channels and one each for the PK black, yellow and the PG black.
Here is the plastic diaphragm (Washer) that makes the two pieces fit snugly together to give a perfect seal between the two pieces.
I would not suggest for a minute that anybody should try this themselves (it usually ends in failure thats why)
because it should not be performed on a perfectly good print head unless you have bought a new one first.
After I soaked it for a week in various substances that I had found under the kitchen sink,
I reassembled it and done a test nozzle print, I managed to get about 50% of the magenta,
cyan and yellow back working again; the other two blacks were at 90%.
Its now back soaking again because it will be good enough for the testing of the proper I.S. GO,
a few missing nozzles wont make any difference to the glossiness,
another week or so should do the job..
