I'm not regularly using my PIXMA Pro 9500 Mark II. Tried just leaving the Printer setup w/tanks and monthly "Nozzle Check" printing but that really hasn't worked out - Tanks seem to go empty without use (Ink evaporation?) over time and now some/all nozzles are clogged. Total use was a single set of Canon ink.
So, I've begun "cleaning" the printhead according to the threads in this forum. And I say "begun" because it's been 2 days of repeated soaking (water & Windex) and flushing. Flush water is still not running clear and a few of the filters continue to show color. I've also noticed what looks like small particles focused around one printhead column/row - Almost like the filter flushing has pushed them through but now they are stuck. Wasn't like this when I started.
My plan is to complete the cleaning and then store the printhead w/o tanks until next use. I guess at this point, the questions are;
How do I know when the printhead is sufficiently clean enough?
If I need to be a little more aggressive would ammonia be the right liquid choice?
Do I just let the printhead air dry as the final step?
Anything recommended to clean on the Printer side?
Thanks,
Bob
Rochester, NY
Thanks,
Bob
Rochester, NY
