- May 29, 2007
- Ghent, Belgium
- Epson SC-P800,WF-7840,XP-15000
Yesterday I was sent a new resetter, because the first one I ordered was DOA.
The resetting is just as easy like the famous Sudhaus Redsetter. Take a look:
The small blue panel is for aligning the smaller CLI-521 cartridge towards the resetting pins. Remove this if want to reset the bigger PGI-520 cartridge. I discovered you only need a small push to reset. Pressing too hard will cause the reset to fail !!!
The last picture shows the LED turning red after a succesful reset:
Best part of all: the battery can be easily replaced:
The cover is easily removed by just pulling it a bit. There are now screws and the lid is just snapped into the housing:
Just pull out the small circuit board and you can replace the battery:
