I refill with MIS inks and had to replace a Canon iP6700D printhead about a year ago because of ink-starvation problems in the black nozzles. This is separate from plain old clogged nozzles, because an ink-starved head puts out progressively less ink the more it's used until it becomes useless. The ink-starvation also doesn't always show up on the nozzle test print, but will be obvious when something is printed in the fastest draft mode.
A few days ago, I started getting this problem in the yellow of my "new" printhead -- banding when printing in fast modes. Everything I tried either didn't work, or made the head worse, and I figured I was going to have to buy a new head... Until I stumbled on a method that restored the head to fully working: Make sure the printhead is rinsed and has no ink in it, then simply blast the head's ink intake ports (not the actual print-nozzles) for a minute or so each with a Waterpik. I hold the Waterpik nozzle until it's touching the intake port screen/filter, and move it around so it hits every part of the screen. That's it!
Some notes:
1. Blasting the actual print-nozzles with the Waterpik doesn't seem to be necessary. If you feel compelled to blast the nozzle area, I'd suggest holding the Waterpik well-back from the head to avoid damaging the nozzles. Definitely do not touch the Waterpik to the nozzle area. (I never touch the nozzle area with anything, ever. No fingers, no paper towels, nothing. I never use chemicals, either.)
2. Make sure the head has no ink in it, and you and the surrounding area are safe if they get wet. This is going to splash everywhere.
3. Make sure the printhead electronics are dry before reinstalling the head.
4. Important: Do not force water through the head after you clean the intake ports. Forcing water through the port and out the nozzles will make the "clog" worse, whereas Waterpik'ing the port will make it better. This is a total mystery to me, as in both cases water is moving through the head in the same direction.
I've never seen this method mentioned before. I did this a few days ago and have printed a bunch of stuff in draft and high quality modes, and the problem hasn't recurred.
Some notes:
