I've searched the forum and was rather surprised that this use was not discussed, and was equally surprised not to find (wondering just how I should have searched...) any summary of manufacturers and ink sources.
I'm resurrecting (maybe starting to use again is more accurate) an Epson R380 that I have had for a while in order to start printing topographical maps, and other information on "tear-proof" and "weather-resistant" adventure paper. I'm hoping that someone has some experience with inks and this printable membrane sheeting. My past experience with aftermarket ink and this adventure paper has not been good. More about the paper below.
As side note number one, I also want to use the printer (as I have in the past) to print labels on CDs and DVDs. I also want to take some of the load off my dye-sub printer (a Kodak 8110) to put off replacing it for a while longer, so I think I want to print more photos on this printer as well
Side note number two. I am seriously considering looking for a new or used large format (accommodates 11 x 17 inch adventure paper) printer so that I can print larger topos and charts (the current printer is limited to 8 x 14.) I'm thinking Epson so that I don't have to start over with this ink research, and maybe I can use the same ink in the two printers. Comments about different printers needing different ink (and the recommendations as to printers) are very welcome.
I have previously used the adventure paper with a HP DJ 960 and then a DJ 995c. The 960 died from "ink poisoning" and the 995 stepped in, but neither had a crisp output with the adventure paper. I have an HP DJ 1220c sitting on the shelf, but my gut instinct is that the R380 could give better results, and if I want to print larger format, I should look at newer Epsons (probably a used or re-manufactured unit.)
Adventure paper, sold under the National Geographic name, is a waterproof teslin printing material that is very tear and puncture resistant, but can be printed on in an inkjet printer. Once dry (about 10 minutes) the ink won't wash off. Or at least it usually doesn't. Here's problem number one. When I switched from HP cartridges to re-manufactured cartridges, the red ink would run even if it were sitting for days. Yes, only the red, not the black or the blue. I switched to another re-manufacturer, actually another brand, and the problem stopped. The other problem, and part of why I switched from the HP inks was that the colors came out a little funny, just enough to be annoying, but not wreck the usefulness of the topo.
The color issue was only on the adventure paper, and the same image on regular paper looked ok.
Having switched to an Epson R380 to print CDs and pictures, I was a bit disappointed in the photo color (I have a black dog and photos of her looked off-color, more blue and grey than black.) The photos also had lines from (I presume) the print head, so I chalked that one up to "you get what you pay for" and buying a remanufactured printer. Good news was that printing on the CDs and DVDs was just fine and that was the most important job at the time. I haven't printed a topo yet, but I'm not in a hurry to print as I am near the end of the last set of OEM cartridges and loathe to spend another 50-60 dollars on a new set before I get aftermarket ink (and cartridges?) ordered and in hand.
So, I started looking for an aftermarket source of replacement cartridges. I started realizing that things have come a long way since the last time I looked at ink several years ago.
I started doing some research and felt bombarded with options without any way to sort out the wheat from the chaff. Ebay seems to have hundreds of sellers and no way to sort out the good from the bad. The rest of the internet is only marginally better, with sites like this being where the answers hide.
There seems to be at least one way to attack this, which is to start testing various inks on the paper, but I'm hoping for advice and recommendations to cut down on the number of inks to test. Also, I'd rather have a ink that is good at all three uses, rather than perfect for the adventure paper and mediocre for the CDs and pictures.
I like the idea of a CIS since it seems like I go through a set of cartridges within about 10-15 full 8x10 pictures and I'll print out 5-10 topos at a time (to give to members of the group) and I'd rather not replace cartridges every 2-3 weeks in the winter. The flip side is that having that capability isn't critical and I don't know what down sides there are to using a CIS.
I'm not afraid to refill cartridges. I was doing that on HP and cannon printers for years, with varying results.
In the end, I just don't want to waste time and energy (and money) if people have advice and experience that will prevent my missteps.
Thanks for taking the time to advise me, and you can either post here, or email me direct at ghopper@eskimo.com Also, if there is a more appropriate forum to post this on, please let me know.
I'll be more than glad to post my results so that others can learn from me!
Grant
Grant
