- Thread starter
- #31
balloonshark
- Apr 11, 2011
It is the original OEM cartridge that came with this reburbished printer.stratman said:Could be the chip malfunctioned or has been damaged. Doubt the resetter is the problem since the other chips were reset, but anything is possible I guess. If this is from an aftermarket cartridge/chip, that could be the reason - incompatibility or lax manufacturing standards. The forum strongly advises all OEM cartridges for multiple reasons.
Sorry, I meant nozzle check. The weird part is that the printer is showing the yellow ink level as full but when I open the printer the red ink lamp is off for the yellow. In all honesty 3 of my cartridge ink tanks were dry and the printer has been sitting for well over a month while I gathered info on how to fill cartridges. I'm really hoping it's not a clogged print head but seeing how the other colors work it could be that I screwed up the cartridge.You say that Yellow wasn't recognized but then say the other colors printed a "test pattern". What is this "test pattern"? You should only be printing nozzle checks until all cartridges are working. Also, it is my understanding that chiped-cartridge Canon's won't print unless all cartridges are "recognized" and the chip is not marked as empty (or an override has been performed). How did you get it to print if Yellow is not "recognized"?
l_d_allan, Thanks for the tip on RJetTek! As you can see I still need hand holding but perhaps I'll consider them when my existing ink supply runs out. Hopefully they have reasonable shipping rates.
