NeptuneNancy
- Feb 1, 2010
This morning, after printing one page, we got an error code on the MX850 - "5C00" (if I'm remembering correctly). Looking online, I read that "fixing" this problem involved absorbing the ink from a small, approximatey 1" square foam pad that resides under the ink carriage when it's positioned all the way to the right. My husband has done this in the past a few times (maybe for an A600 error code? I'm not sure). I then read that this pad does lift out, and the recommendation was to lift it out, squeeze the excess ink out of it and replace it. Sounded good, as I thought we'd have to do this less often if I squeezed enough ink out. It was going well, until the tweezers I was using slipped and the pad went flying. I think it's down in the printer somewhere on the right hand side because I can't find it.
I've lifted and moved the printer around (gently!) every which way, hoping to get it to drop to a spot where I could lift it out. No such luck. I decided to take my chances and plug the power cord back in to see if I still got the error message. No - the usual display when it's ready to print came back on. So, I tried printing a page - and it worked! It took awhile to print, sounding like the carriage was moving back and forth more than usual before beginning to print, but it hadn't been powered down in a few weeks. So far, it looks like the little lost pad isn't interfering with anything mechanical. *fingers crossed*
My problem is I'd like to buy a new little foam pad to replace the one I lost, as I figure it played some important role in the functioning of my printer. Does anyone have an official name for this pad, or a part number and maybe a website where I can get one? Does anyone know the approximate cost? I figure I can call Canon, but I don't know what to ask for.
Thanks in advance~
Thanks in advance~
