mrelmo
printer is not working uggggh, error code 6C10 turn power off then on, if it does not work refer to manual, well the manual has no info on the error code, turned printer off and on several times no luck, pulled cartridges, print head and reinstalled, all cartridges light up, communication appears to be fine, even when you attempt to scan everything goes good until it gets to the printing then the error code pops up has anyone come across this code, one fix i found on the net said power down open then power up but no luck
