MP830 error - Paper output slot. The paper is jammed clear the paper and press OK
jimbo123
USA - NJ
MP830 MP980
a recently acquired canon MP830 is giving me the following error:
Paper output slot.
was doing a nozzle check without connected to any computer. paper was fed by bottom tray, got stuck and i pulled it out.
have looked for any scraps, tried feeding cardboard through the back, but to no avail
have tried compressed air, looking in all the usual places, can't find any paper, etc
just can't clear the error. it comes on during self test, even with no print head in, etc
have heard about the out the output tray sensor, not sure where that it or if it can be replaced. i do have a few MP830s w spare parts
any ideas ?
thx
J
• Active Printers: MP830, MP980, PRO-100
• Stored Printers: MP830, IP4500, MX700, MX860, MX870
• Ink: Hobbicolors and OCP
Possible solutions:
Make sure to unlock the scanning unit before turning the machine on.
  1. Lift the document cover open.
  2. Slide the scanner lock switch to the release mark.
  3. Close the document cover.
  4. Press <ON/OFF> to turn off the machine.
  5. Wait approximately 5 seconds then press <ON/OFF> to power back on the printer.
https://support.usa.canon.com/kb/index?page=content&id=ART153395
https://www.printerknowledge.com/threads/mx870-says-paper-jam-in-output-tray-not.6358/
https://answers.microsoft.com/en-us...r-jammed/4568d60c-a76e-450a-bb1c-982d77bddc0e
jimbo123
USA - NJ
MP830 MP980
thx
J
Are you getting any other indication of malfunction such as blinking lights or an error code? For example:
Cycles of blinking in orange (Alarm LED) and green (COPY button)
14 times
Error
Paper feed cam sensor error
Error code
[6B10]
Conditions
An error occurred in the paper feed cam sensor during paper feeding from the front paper feed cassette. This error is also indicated when the waste ink counter is 60% or more, and a paper jam occurs in the under guide.
Solution (Replacement of listed parts, which are likely to be faulty)
- Sheet feed unit
- Logic board
Not sure what the "under guide" is. Could it be the waste ink counter is 60% or more which contributes to the issue? Would a reset of the waste ink counter resolve the issue?
jimbo123
USA - NJ
MP830 MP980
stratman,
great info and tips. no blinking lights or error codes, can't print out the service mode report yet to see what the waste pad count is.
might try a waste pad reset anyway to see if that helps.
i picked this up for $15 mainly for the scanner/ADF unit. i have 2 MP830s that print fine but the scanner units died, so working on yet another backup.
these printers are over 10 years old, refill easily and just need some tender care every now and then.
build quality is worth the effort to keep these going.
J
Agree. They are terrific.
I also have one with a bum scanner unit that needs replacement.
jimbo123
USA - NJ
MP830 MP980
quick update
i was able to pull an service mode eeprom report, unit is at 84% waste pad usage.
i tried to resolve the error, compressed air, shook it upside down, reset waste pad counter to 0%, all to no avail.
given the 84%, i have decided to pull the working scanner/ADF and put it on my old MP380 that has 63,000 printed pages on it whose scanner/ADF died.
thx for all the help, hard to believe these printers are 10 years old and sill kicking/refilling.
J
Thanks for the update. Like organ transplantation, the scanner unit will live on in its recipient. Sacrifice for another is the theme of this day.
Paper output slot.
It’s possible that when you were removing the jammed paper, you have pulled or knock the mechanical paper sensor backwards, (Bent) and its still in the paper feed position, removing a paper jam is not always straight forwards.
Look for the little plastic arm sticking up on the paper path...
jimbo123
USA - NJ
MP830 MP980
any chance you could take or find me a pic of the "little plastic arm" ?
might help to see it in it's proper position
thx
J
