- Nov 27, 2010
- Copenhagen Denmark
- Canon MP990
I guess you had a cartridge leak? This certainly can damage a printhead. It has happened to me in an iP4200. Some bad quality third party cartridge leaked, and the ink formed a film on the underside of the printhead. Some of this ink crept under the conductors and caused a short circuit that took out exactly half of the yellow nozzles.
Probably the catridge stopped feeding ink to the printhead even if there was ink in the ink chamber? This is ink starvation, and could be caused by problems with the vent. You didn't forget to remove the vent sealing tape?
Both ink leakage and ink starvation can kill a printhead, so it is best to use only OEM Canon cartridges, either new or refilled with a good brand name refill ink.
Your description of the error with PGBK or other band cut at exactly 50% perfectly fits the the description of electronic printhead failure. If this leak also damaged the motherboard I cannot tell.
