A cool place is always better because it slows down chemical breakdown which is always happening. So the coolest place short of a refrigerator is probably ideal.
The other thing is that I would actually stick with 2oz squeeze bottles for Canon pigment as it is becoming clear that these Canon pigment printers are more sensitive to pigment ink physical properties than previously thought. With the smaller bottles there is less air volume for the ink to vaporize into and become thicker so it will slow it down.
The above photo I previously submitted is what happens when you attempt to use ink with the properties of the 9500 in the Pro-10. Ink delivery issues. It gets worse if you use PGI-9 carts. indicating that the internal properties of the spring might have shifted as well. This necessitated a totally new inkset for the Pro-10 from the ground up and hence the delay in the inks for that printer. Since I am funding the development, those new inks to be made by IS will be exclusive to myself.
Rod I would like to obtain the old ink. Please check your PM.
