- May 7, 2011
- Location
- United States
- All of them! LOL
I'd like to share my latest printer project with you guys.
I had checked my Artisan 720 which is running currently on a CISS from Precision Colors, with the WIC tool and the main waste ink counter was up to about 80% so since the waste pad box unit it is a user replaceable item, I decided it was time to look for a replacement.
Well, I could only find then available on our good friend's octoink.co.uk site.
So while looking around I discovered Martin's great instruction on how to install the Printer Potty to an Artisan Printer.
I substituted an empty 110ml ink bottle as the waste ink receptacle. I may still purchase a Printer Potty for it at a later date as it is a hell of lot more elegant!
Installation was extremely simple. Remove the waste ink box screw in the rear of the printer. The unit then pops out and the Waste INK Tube from the purge unit lips out of a small plastic receiving box that is part of the waste ink box. There are pictures of the unit in the instructions. I could have purchased a replacement unit from Martin but I was on a hurry so I chose to go with waste ink bottle for now.
So basically you completely remove the waste ink box and you end up with the waste ink tube looking at you. I then press-fitted a single length of CISS tubing into the printer's existing waste ink tube ( tight fit ) , and threaded it out of the printer through the screw hole that held the waste in box in place. I secured the new tubing internally against the inner wall of the printer case with a piece of clear packing tape. It's not going anywhere!
I did not have to enlarge the screw hole to pass the tubing so if I choose to install a new waste ink box at a later date, I will be able to, as the printer has not be modified in any way.
With the length of tubing now out of the printer, it was simple thing to slip the end into a matching hole on the bottle cap. A small vent hole was also drilled.
I tested the modified system by running a cleaning cycle. Waste ink drained perfectly into the bottle. No leaks anywhere.
Now for the resetting of the waste ink counters.
I could have used the WIC tool with a $10 serial but I found the actual Adjustment Program on EBAY from the UK for a bit more but unlike a tool requiring "Pay Per Use" serials, adjustment programs can be used for an unlimited number of resets. They also provide you with many functions best left to the printer techs.
Once it was emailed to me, I proceeded to successfully reset both counters back to zero.
If you don't know how to use adjustment programs, I would still recommend the WIC tool as it is relatively easy and pretty much foolproof.
Joe
Joe
