- Jan 18, 2010
- Residing in Wicklow Ireland
That depends on two key questions first.
(1) do you print a lot or intend to do lots of printing ?
(2) do you print very little or fun print occasionally ?
**Now for the occasional and fun printer guys the answer is a No, refilling would not be cheaper but you can get compatible pre-filled cartridge at a very reasonable price so you dont go broke buying OEMs carts.
For the compulsive and dedicated printer guys who cant get enough of printing and print everyday for the pleasure and enjoyment of it then the answer is definitely a Yes..
The very first initial investment into refilling can sometime seem very expensive to a first time refiller and can actually put them off the idea altogether because of the big outlays involved.
To refill properly youll have to have the bare minimum of items and that is usually 90% of the total cost straight away, but once you have that then your savings are going to be very very considerable.
** Occasional and fun printer guys can also refill their cartridges but it would take them longer to recoup their original outlay so it certainly would seem not worth it to them in the long run at all.
Make no mistake about it guys, if you try to refill on the cheap by cutting corners then it will cost you a lot more than just an occasional spill of ink and Technicolor surroundings, it may even cost you your printer as well.
So guys Happy Refilling to all you adventurers..
Footnote: - CISS are good but Refilling is much better..
A set of cartridges costs me over $100. Equipment and a generous amount of refill supplies, maybe $40-50. You can also get small OEM cartridges, but those are way too expensive for what you get.
