Hello,
I'm struggling with a bunch of issues and hope to resolve. Tested print heads, by cleaning/deep cleaning, nozzle check etc and had to remove print head for soaking and cleaning. I was getting no pigment black printing (B+W prints) and streaky other colors. Hopefully soaking etc. will help with pigment black etc.
I've been refilling via German method and have had assorted issues over time. Sometimes one color like magenta takes over and tints everything.
Now it's (non-pigment) black. Before I started the soaking mentioned above, I filled up all colors, and black (non pgmt) drained out within a day or 2. Thought I must have forgotten to fill black so repeated and a couple days later and all drained out.
All of the print colors were tinted grey-ish. Removed and looked at carts and now yellow cart seems to have absorbed black ink - yellow sponge is half-filled with blackened ink and reservoir ink (ink-fill area) looks black.
I saw some posts about German method that said to drill hole + insert the needle a little higher than at the base of the sponge (as I have always done). Perhaps this will stop the ink from leaking out of the black? (I'll need a new cart to drill higher)
The black (non pgmt) sponge seems totally saturated and might be best to start with a new cart anyway (?).
I think I need a new yellow cart because I can't see how I can get all that black ink out of there.
There seems to be a mess of excess ink inside parts of the printer (I guess that's par for the course). Tried to clean up with Q tips but I'm not sure I need to get all that out of there (or if all printers are just somewhat messy inside?)
Any advice/thoughts about the black leaking out and contaminating the yellow cart would be especially appreciated.
Also thoughts on German method VS top-fill method (with silicone plug) would be appreciated. (I think the Freedom Method will be problematic for me/my wife to try.)
Thanks in advance for any advice!
PS: Also, I do not get any message when inks are low on my ip5000, which causes tanks to empty out without us realizing. Suggestions for fixing this other than manually checking ink levels often?
