ip4600 dispenser! doubts ? updated 9/08/2009
alimao
follows the photos, which can be the dispenser of the ip4600 ink !!
the doubt is! Remove that hose to put the external dispenser?
what?
When I took apart an iP4000 I found that the waste pump used TWO tubes to pump ink out of the printhead into the waste pads.
Looking at your last picture it's very likely that both of those tubes you see connecting to the white block (under the yellow wires) will need to be redirected to an external waste tank.
Only way to be sure is to disconnect them and extend them out into a container then try running a cleaning routine. If you get a mess in the container, you were right, if not, you were wrong... :)
alimao
trash found the ip4600
follows the photos
more barriers to the problem
I have no idea how to pull the hose out of the printer accept suggestions!
alimao
more photos on the trash found two in total
expect it to help the community forum
