Hi People,
Long time listner first time caller so to speak.
I've been having quite a bit of bother with my printer as of late.
I am currently using refills in the IP3000 and up until now this has not been a problem.
What is occuring is that Yellow will print without issue. In fact it prints so well everything has a yellow hue to it at the moment,
cyan prints fine (Blue right?) magenta prints fine. However:
When i do a nozzle check and it shows for example a full strength Cyan, Magenta, Or Yellow underneath that horizontal bar of color there should be a half strength print of that color... I'm not getting th ehalf strength.
Printing isn't working correcting in that the colors dont seem to be mixing correctly.
Long storey short I have a test pattern i'm trying to use and the grey border around it just prints as yellow.
NOW... this same test pattern, if i print it continuously for about 12-15 prints, all of a sudden it will print fine. So long as I dont let the printer sit for more than half an hour of idle, I can keep printing photos, cd's documents u name it .. its as if there was nothing wrong with it. However... leave the printer for an hour and BOOM.. back to square one needing to print another 15 wasted pages to get printer going again.
I've replaced the cartridges in case they were the problem, tried diff gromits to plug refill holes and that hasn't helped, tonight i stripped the printer down - washed out the ink sponges in the base of th eprinter and have blasted the purge lines with water. The only one that seemed to initially need some sort of heavy pressure applied was the black.. Now they're all flushed and printer is outside in the dark drying for tomorrows tests.
Ohh as a side note, if i print a black word docuemnt, everything prints out fine.
If i could work out how to upload pics i would....
Does anyone have any ideas of what to check or what could cause this kind of behaviour?
