- May 29, 2007
- Ghent, Belgium
- SC-900 ET-8550 WF-7840 TS705
Most desktop printers for common use are very capble of printing more than decent photo's which easily rivals the quality from a proffesional photolab. However: getting high quality B/W prints one must have either a good calibrated ink/paper combination or even better a printer using dedicated black/grey ink cartridges to ensure neutral B/W printouts.
However: those printers tends to be only large format like the Epson R2400, Pro 3800, HP B9180 and the Canon Pro 9500. But these are all pigment ink printers and A3+ and larger. All these printers need the lighter photo magenta and photo cyan inks to have a smooth colour gradient. High quality dye ink printers like the Canon IP4x00 series don't need these lighter versions of magenta of cyan, due to the usage of 2 different sizes of ink droplets being produced by those printers: 1 pl and 5 pl, small enough to avoid grainy printouts. One can compare a printout made with a -for example- IP4500 and a 6-colour IP6700D. Most people won't even detect a difference, when both printers are properly profiled for the respective ink/paper combination.
However B/W printing is still not very optimal and compared to true B/W printers like the R2400 there is still a noticable colour cast to be seen. Canon has now introduced the MP980 printer -sucessor to the 6/7 ink based MP970- which omitted the photo cyan and the photo magenta cartridge, compared to its predecessor MP970, in favour of a new CLI-521 grey cartridge.
So this printer has the following cartridges: PGI-520 pigment text black, CLI-521 cyan, magenta, yellow, (photo)black and grey dye ink cartridges. One pl ink droplets make the usage of LM and LC obsolete and both black and grey ink ensures neutral B/W printouts. And the grey ink improves the gamut of the other colour catridges as well, by laying a tiny amount on the other colours.
This optimal comprimise between the minimum amount of necessary ink cartridges to be installed to obtain maximum gamut is accordingly only 6 with dye ink printers (of which one is pigment text black). Note that the i9900/i9950 does not have pigment black, whether the IX4000/5000 only works with cyan/magenta/yellow to create photo's without dye black.......
One must wait until Canon will introduce a A3+ printer using the same printhead as in the MP980 printer, but with a tubing system like the HP9180 and fed by larger stationary inktanks (at least 30 ml per ink cartridge). I think to myself: just stay on dreaming.......
