lewisham_phil
- Feb 18, 2008
Hope someone can help with a problem on my i9950, which is driving me to distraction!
I started getting slightly wayward printing with a few stripes on photo magenta, and intermittent problems on other colours. Normal cleaning didn't seem to help, neither did cleaning the head, so I surmised that a purge pipe had come adrift, as I had suffered a similar problem a while back.
Sure enough, one purge pipe had come adrift, on the left hand bank; this time I used small cable ties to help keep the pipes in place (not very easy, unless maybe you're a micro-surgeon)
I thought that would be it; but oh no.
Cyan, Magenta and yellow are all fine; they are 'group 2' colours, on the right of the head, and pumped by the right hand pad by the purge pump.
The troublesome inks are all in the 'group 1' colours:
Red and PC are fine; PM is OK, but with a few stripes, however black and green have disappeared completely.
I double checked the purging: Both pads hold water fine, so no leaks or pipes off, and both pads suck voraciously; you can see the liquid disappear and the pads clear; you can also see ink coming out of both outlets below. (the printer is stripped down, and the chassis raised)
The carts are a mix of mainly refilled from Hobbicolors, with two original canon carts (not yet refilled); the green and the black.
In desperation, and possibly not advisable, I tried swapping both the green and the black over to 'group 2' in place of yellow and cyan. After one cleaning cycle, perfect black and green (where cyan and yellow should be)! Also, the yellow was fine where green should be, but no cyan where black should be.
It would appear that the left hand purge pad, although functioning, isn't pulling through as well as maybe it should. But then, the yellow worked straightaway on the left pad, which also I surmise makes a logic/electrical fault unlikely. The black had not been troublesome before I took the head out to clean it (I shall, as suggested by ghwellsjr, try and avoid this in the future, and make up some cleaning carts instead), but now not a single segment!
Any ideas or advice are welcome..I think my next move might be to swap the purge pipes over between the pads.
Thanks in advance....
