i1Pro1 uv-cut version: not sure it will work with OBA containing papers
SC-900 ET-8550 +18100 WF-7840
Today I have found a version D uv-cut i1Pro1 (Fiery ES-1000) device. The device is uv-cut, so I think it will give a yellowish hue in bright daylight for OBA containing papers.
So probably I have to use some setting in colprof to counter the uv-cut effect of this device. Because I am using the device for prints that will be pressed between plexiglass plates or behind glass (reducing 98.5% of UV-light), this might not be a big problem. Anyhow the device was a real bargain.
I received the device today and tested with chromiq and i1profiler that detects the device as M2. I made a test profile on oba containing glossy paper but due to the UV filter the greys have a bluish teint in broad daylight viewing. Not sure if I could counter this effect with a setting in color of. Strangely enough the colormunki is uv cut too afaik.
