I have an Epson L805 6 ink printer. It normally takes epson 673 ink. I have a lot of epson 504 ink. Can I use the 504 ink in the L805 printer?
Don Berto
Matagalpa, Nicaragua
Epson L805
I have an Epson L805 5 color (+ BLK) printer. It normally takes Epson 673 ink. I have a lot of Epson 504 ink. Can I use the 504 ink in the L805 printer?
Epson T673 inks are Dye-based inks.
Epson T504 ink is Dye-based inks.
The L805 uses all Dye-based inks. So, yes, you can use the Dye-based T504 inks to refill your L805 that uses all Dye-based inks. Whether the color fidelity will be acceptable to your eye is another matter.
Beware: Some printers may use Dye-based inks except for one Pigment Black that is used for text such as on Plain Paper setting.
*Please delete the 2 other identical threads you started if possible.*
The L805 uses light inks which you don't have in the 504 ink set, you would need a dilutant to do a 2x thinner + 1x ink mix, or you use the 504 inks CMYK + LM and LC from the 673 ink set.
But - there is a caveat - the 504 inks have a much lower UV/fading resistance than the 673 inks so it's your choice, and you might need to create new icm color profiles if you use a non standard ink set together with non Epson foto papers.
Don Berto
Epson L805
Thank you for the information. I will ues a syringe and remove all the 504 ink I have filled the ecotanks with, as of now some of the inks are mixed. I will order all 673 inks. Saving the money is not as important as creating the best prints possible with the equipment I have been able to afford here in Nicaragua. Vielen dank
