Hello Ink-Teck,
Are you asking how to reset the counter? Or your having a problem with the printer recognizing the cartridge and getting an error?
On most printers that use remanufactured cartridges, you can't reset the counter. However, the printer will allow you to continue printing, but without showing you the ink status. Some older printers (I'm not sure about new ones) allow you to rotate the cartridge. For example if you have 3 cartridges, lets call them A B C, and you refilled cartridge "A" right after using it, the printer will not read it as full. But if you used cartridge "A" then "B", then "C" and went back to "A" and refilled it, the printer will of forgotten that you used cartridge A since the memory couldn't hold more than 2 serials. As I mentioned though, this might not work on newer models.
