How to Print Faster with Your Laser Printer
P
print90
Guest
Various Tips to Print Faster with Your Laser Printer
6 Tips on How to Print Faster
Printers have come a long way, especially in speed. Even inexpensive laser printers these days can print an average of 25 to 30 pages per minute, whereas a few years ago, the number was about 4 to 5 pages. If you find your laser printer is not printing near its stated capacity, there is likely a bottleneck in the process worth investigating.
Six common types are:
1. Reduce Your Quality Setting Print at the quality setting appropriate for your needs. If youre printing a 100 page rough draft that youre gonna toss out anyway, then go for the lowest setting. Not only will you save time, but money and less wear and tear. 2. Split Up Your Larger Documents Printing large batches with your laser printer at one time can overload the buffer or memory on your printer or computer. Try splitting up larger batches, especially those involving high DPI color pictures. 3. Increase Your RAM Many printers have expansion slots where you can insert additional memory. Find out if your printer does, and if so, invest the small amount necessary to increase the RAM available. 4. Ensure Your Computers Cache is used Right click the Print Under Printer->Properties->Advanced. There should be a checkbox next to keep printed documents. This will keep printed documents available for follow up printing, saving time for your print jobs. 5. Use the Fastest Connection Possible Monitor the difference in printing speed between your computer and laser printer. If you notice a faster printing with a direct USB cable, then by all means go with it. 6. Make Sure Your Computer is Not Slowing the Printer In addition to your printer, ensure your computer is optimized. Ensure open applications are closed, unused programs are uninstalled, your drive is defragmented, and most importantly, you have sufficient RAM on your computer.
ThrillaMozilla
"Various Tips to Print Faster with Your Laser Printer"
If you are in the U.S., try running it on 220V instead of 110V.
Don't fan the paper before loading, so maybe it will feed 2 pages at a time.
Use smaller paper.
Use thinner paper so it will slip through the rollers faster.
Spray graphite around inside so the pages will slip through faster.
Print from two computers at a time.
Hook a CO2 cartridge to the toner cassette so toner will come out faster.
Mix graphite with the toner so it will come out faster.
If you're printing a long document, try printing just the first half. You'll never get to the end anyway.
Go out to lunch so you're not waiting for a print job. It will print faster than ever.
Print from the serial port on a 15-year-old computer running DOS. You will need a serial-to-parallel adapter and a parallel to USB adapter. It will print much faster than the latest loaded computer running the latest Windows.
Follow the advice in the first post.
You forgot to turn the printer upside down so that the paper falls out faster. Works really well with inkjets as well.
Also try turning all the text to white. That uses less toner. So the printer will print less faster.
Can you use white ink on gloss as well as matte paper, and is there any visible bronzing with that ink?
Actually there probably exists white toner somewhere.
I imagine you can use this on recycled documents. First run the paper through your printer and print a solid shade of black. Then send it through the laser printer with the white toner. This is a great way to reuse paper that has already been printed on. With this method you can reuse paper over and over again. The next time, send the document through the printer with white toner to get a white page. Then switch back to black toner. Can you imagine the paper you will save!
Am I the only one imaging a run on baby talcum powder supplies?
Sweetest smelling white on black documents you could hope to ever achieve... :)
You sure that white stuff on you nose is baby talcum? and you love smelling it
Try telling the cops that!
