Hoping for help with Brother MFC-495CW (LC61 series)...
tmgenterprises
Print Lurker
Brother LC61 Series MFC-495CW
A few days ago, my printer stopped working. I had just tried to print something and all the function buttons lit up at the same time. The display is backlit but nothing appears on it and none of the buttons work, including the power.
I had moved the printer downstairs to the living room the night before in order to get a fax (phone line isn't upstairs) and had just brought it back up. I printed two or three other things without an issue, other than they seemed slow to print at the time, then the above happened.
Anyone seen this type of thing before? I'm at a loss as to how to try to fix this. It's not worth taking to a repair person when I can get a new one for less than $100, but I hate to buy another one if this can be fixed fairly easily.
costadinos
Cyprus
7900, 4900, 9890, R2000, P50
Try resetting it through maintenance mode.
Unplug the printer, then plug it again and turn it on while holding the "MENU" button pressed, this should enter you into maintenance mode.
Then press 01 (the reset code), followed by "START" and 99 to exit...
