Hi, it's been a while. I've been busy printing lots!
Heres a preliminary review for the Hobbicolors UW-8 ink in the ip5000 printing on Costco Kirkland 8*11 and 4*6 glossy microporus paper. This review is for (4) color CMYK and does not include PM + PC. I should mention that technically the UW8 ink is formulated for the newer generation of Canons not my ip5000, but Dave from Hobbicolors said he uses it in his ip6000 with no problems as have his customers.
The good:
Excellent color balance, just about perfect. True OEM killers using default print settings and no profile required. B/W is very neutral with default printer settings. Gradients are very smooth. Gamut is as good as Canon OEM bci6 series and perhaps better. Cyan is certainly denser than the old Hobbicolors bci6 and magenta seems denser and perhaps more vivid. UW8, unlike the Canon OEM ink, doesnt require an increased intensity setting for prints to pop. Dave of Hobbicolors has been very helpful. Extremely pleasing prints!
The bad:
Ink-flow from the cyan has a reoccurring problem requiring MANY cleaning cycles before producing those perfect prints without serious artifacts. I think the cyan is leaking and pooling on the print head which causes contamination, misfires, serious color shifts, banding, etc. Hope it's just the cart and not the ink viscosity. Dave is sending a replacement cart and cyan ink. I already went through a magenta and cyan refill just trying to figure out the problem and running deep cleaning tests.
I now have about ~20 4*6 perfect color photo prints including grayscales that are the best I've ever printed.
Unfortunatly, I also have ~30 double sided plain-paper pages of gradients (to clear nozzles) and nozzle checks.
When I swapped in the old Hobbicolors BCI-6 cyan cart (which appears to be the same make) the print issues resolved quickly. Putting the UW-8 cyan back in the problem immediately returned. Unfortunately the BCI-6 cyan is too light for the other UW8 inks. Again, hopefully it's just the cart and not the ink viscosity.
Will update this review when the replacements arrive and then again later on fade resistance. Feel free to use this thread to post experiences with the Hobbicolors UW8 ink in (4) color and (6+) color printers.
~cheers
The good:
The bad:
~cheers
