My first post here. First of all, I would like to say thank you to all who contribute to this forum. I was having a problem with a bad case of a clogged printhead and using the wealth of information found here I was able to resolve it using the windex soak solution. Now, I am hoping that there is a solution to other problem I am having with my two Canon printers, ip5200 and ip4700. The issue I am having is on both printers, using OEM Canon ink ( I have also used G&G ink) and OEM Canon glossy photo paper, no matter what profile I chose under printing preferences, when printing photos everyone comes out like they have a sun burn. So I did a test print and the result I got is as follows:
1. Cyan comes out more like blue
2. Magenta comes out more like red
3. in the black greyscale patterns, instead of grey all the patterns have a hint of brownish color tint to them. I am having a very difficult time to get grey to come out as grey. They come out more as dark brown.
The only time I can get what appears to me as accurate color, and get a perfect black greyscale is when I print on a plain paper using the photo glossy paper plus setting under printing preferences. Is there any thing I can do it correct this problem. I just went through an a set of new cartridges, trying all the available profiles and none helped. Thank you all.
Windows\System32\spool\drivers\color" folder. Do you see some files that look like "CNB5pEAA.ICM"? Google each file name (without the ".ICM") and you can find which printer(s) each profile is designed for. Do you have the appropriate profiles for your printers on your system?
