Hi,
I have a Epson stylus 880 (bought in 2001) opened and first used in 2011 with CISS.
Magenta won't work, a syringe with isopryl alcohol doesnt budge the clog as NONE of the solution makes headway no matter how much pressure I exert.
Is there a way with the thinnest of thin straight pins to push through the clog via the magenta nozzle itself from the print head carriage and clear the clog?
Black printing is fine by the way.
Is it possible to remove the printhead and externally clean it and put it back?
Thanks,
jeff
Thanks,
jeff
