Hello my friends help I have a Canon printer mf3010 you copy a white paper
bahaa
Iraq
canon
I have a Canon laser printer when I copy paper white paper shows that the ink cartridge in which the new what to do
Is there a solution to this problem :(
@bahaa what exactly do you mean by I copy paper, is it when you print something but your printer only outputs a blank sheet ?
Come back to us with a lot more information please..
bahaa
Iraq
canon
When do I put the paper on the scanner and diamond Please click on the print out a white paper
bahaa
Iraq
canon
the hat When do I put the paper on the scanner Hat and press to print out a white paper
OK you’re not that good at explaining in English so can you write up your problem in Arabic and see if we can understand you more clearly, or better still use https://translate.google.com/
For what I can get from your previous posts it would seem you may have run out of toner..
Can the printer do a normal print from the computer? If it can, then I think it is a scanner problem.
