fix misplaced canon ip3600 spring
dontbehzad
Hi. i removed one of springs in my ip3600 printer and now i cant install it again correctly. I wish if you can take a picture of this part of a working ip3600 printer
h t t p : / / dontbehzad.persiangig.com/1.jpg
thanks
Tudor
Cluj-Napoca, Romania
Epson L800, 1400; ML-2165W
thanks
I hope it helps.
dontbehzad
Thank you very much
in order of your images i placed the spring. is my installation correct?
Tudor
I don't know. I would have to dismantle the printer to get to that position, and I can't do that. It is still under warranty...
L.E.: Ok, I used 2 small mirrors... It looks exactly like that. If your printer is still opened, could you take some pictures, please? Thank you!
dontbehzad is my installation correct?
You spring reinstallation looks good to go but why did you take it off in the first place?
Good on you Tudor, Nice pictures.. :thumbsup
dontbehzad
i closed the printer cover and again get this error "service error 6c10"
Tudor
Download this software: https://rapidshare.com/files/1749656189/ServiceTool_V2000.exe
With the printer turned off, but connected to a power source:
-press and hold the cancel button (lower)
-press and hold the power button (higher) - now both buttons are pressed
-release the cancel button, then press it twice - now only the power button is pressed
-release the power button - the printer is now in Service mode
-start the software and press the "EEPROM" button in the Main-Print section of the software.
The printer will print a page and the first two lines look something like this:
What is your "D" value?
If it's high you will have to reset it to 0:
1. Select 0
2. Press the 'SET" button.
Wait for the software to finish, then close it.
Turn off the printer, then back on.
Oh, don't lose the printed page, you may need it sometime. And don't press any other buttons in the software (unless you really want to ;) ).
dontbehzad
dear Tudor
before i press the "EEPROM" button the lamp flashes (orange and green) and i cant print any things
I have a Pixma 3600, but sadly I have not been able to find a free service manual. However the Pixma 4700 and Pixma 3600 appear very similar, maybe the differences are only CD print capability and maybe a printhead with more nozzles. A simplified service manual for the Pixma 4700 is found here: http://www.gondack.com.ar/media/useruploads/files/ip4700-ssm.pdf
I think the Pixma 4700 service manual might be useful in troubleshooting the Pixma 3600. From page 9/24 of this manual it is seen that the error 6C10 is most likely caused by the purge unit, so my guess is that the spring is not placed correctly (yet).
Good luck with troubleshooting.
Peter.
