- Aug 23, 2006
- Europe EU
- Canon, Brother, HP, Ricoh etc.
Hello, EPSON has not so new but a Printer with built in OEM CIS System, and 70ml ink bottles as refill.
The printer was sold first in eastern countries the last one was russia before selling in europe.
The printer is expensive at 320$ as it;s only A4 dedicated DYE 6 ink photo printer
As you know the L800 is built on same base as P50/T50 printer and uses same printhead.
There is an article about this printer in russian you can use google translate.
The refill bottles look like this (cost 15 or 20$):
But the inks are third party, you can see written EPSON on the bottles, but the ink is not claria ink you would think it is.
Claria inks stabilization graph:
The graph shows that in 2 days the colors are stable.
Now taka look like L800 OEM inks:
The inks are not stable even after 5 days !!!
The following test shows diluted (500ml water with 1ml ink) black ink from L800. The test shows that the OEM ink sold with EPSON brand name is bad quality:
As you can see claria ink is neutral when all others have a tin to them. The worst seem to be
the praised INKTEC, OCP, and obviously L800 OEM EPSON ink.
You can read the russian review here:
http://www.dctec.ru/dir.php?id=78
Also I'll post some problems from another forum where multiple users had same problem with banding printing photos in photo mode, even best photo mode with RPM did not solve this. If you use glossy paper the banding can be seen no matter what. The uses had printer serviced in local service centers, hoewer the problems were not fixed. The service centers said there is no problem.
