- Oct 27, 2005
- South Yorks, UK
- Epson, Canon, HP... A "few"
Having been forced to return to the old trusty Epsons recently I've discovered a few home truths about their setup and particularly in terms of what not to do.. So here goes with a few "Lessons I learned all over again"
1. Spongeless cartridges as part of a CIS require some other form of baffle to stop ink from free flowing.. Either:
a) an air bubble in the top 10% of the cartridge
OR
b) a sponge as part of the whole loop..
Preferably both..
If you don't have this baffle you will likely end up with a free flow, especially if you have 2.
2. Attaching a waste ink tank to the printer is a good thing except when you have such a long tube to the tank and a printer placed on high that such a placement results in a strong syphon effect. It is wisest to have the external waste ink tank just under the printer and preferably with a loop of tubing so that the tube drops to below the waste tank and then back up reducing the pull pressure on the ink.
3. Spongeless cartridges need to be primed and kept upright to avoid air bubbles getting into the exit port and causing an air lock in the printhead. If You find this happens anyway then the use of a bottom fill adaptor and a syringe to draw ink through the loop and air out of the exit port should fix the problem.
Bottom line: air moves more freely in a spongeless cartridge so more care needs to be taken with keeping the cartridges in the correct aspect/orientation.
You can imagine what the past few weeks has been like can't you... Ah well.. lessons relearned.. :/
OR
Preferably both..
