Epson 2700 All Lights blinking
Tyler Pickering
Epson 2700 Ecotank
I tried to print something today and my printer made a weird noise and pulled the paper in about an inch then all the lights started blinking. There wasn't anything jammed in the printer and I followed all steps on the Epson website as well as calling their tech support ( Who were completely useless by the way).
Do you guys have any ideas?
Epson said to call back monday and their advanced support would see about replacement ( This would make it my 4th replacement for the original printer)
Take the replacement and run.
Otherwise you may need to be more specific on that happens during this malfunction, such as what lights, do they blink in a repeated cycle, and if so, how many blinks per repeated cycle.
Tyler Pickering
Epson 2700 Ecotank
All lights blink. Error code 000041. Second time this has happened, they replaced not even month ago because of it.
I would definitely not recommend to anyone to purchase a Ecotank-2700 and I should've done more research before purchasing.
Unfortunately if you're getting replacement printers you are getting units that have already failed, barely been refurbished and then just shoved out the door to fail for someone else.
I would take the replacement one more time but at the same time I would consider consulting your consumer rights to see if you can force them to replace with a brand new model instead of refurbished units. Good luck either way!
You may run the status report of the WIC Reset utility ( I think it only runs on Windows) ,the report lists the
last 5 critical errors with the failure code and a short description. This may point you into the right direction.
